Engine shuts off???
Old Oct 24, 2020 | 10:54 AM
DannyC's Avatar
Default Engine shuts off???
Hello,
I have a 1989 IROC Z-28 with a 5.0 Liter TPI V-8 engine. I’m having 2 issues.
1- the engine runs rough when cold and takes 15-20 minutes for it to run smooth.
2- the engine will shut off on its own with no warning. This is a intermittent problem.
Does anyone have have any suggestions on troubleshooting?
Thanks,
Dan
Old Oct 24, 2020 | 01:01 PM
Everett#2390's Avatar
Disconnect battery for min 10 minutes. Ensure intake duct work and filter are clean.
Hook up battery and let PCM, er, ECM relearn.
Old Oct 24, 2020 | 06:25 PM
Check your fuel pressure too, your fuel pump might be pooping out.
Old Oct 24, 2020 | 08:36 PM
DannyC's Avatar
Hello Everett and Camaro 69,
Thanks for the help, I’ll look into your suggestions.
Cheers
Old Oct 25, 2020 | 07:46 AM
Running rough cold can be a tuff one or it can be very basic. I would start with basic tune-up stuff. Plugs, wires Cap rotor, fuel filter, retorque the intake, check and clean EGR valve and IAC motor. Search Youtube for "how to" videos,
When it completely shuts off things are a little more straight forward. When the engine is not running check to see what is missing. Fuel or spark. To check spark just get a cheap inline spark checker, you should get a fuel pressure gage and a fuel injector noid light. .
Old Oct 25, 2020 | 10:05 AM
DannyC's Avatar
Thanks for the help Gorn,
I will look into your suggestions.
Cheers
us63bravo
Jul 29, 2011 08:14 PM
Lanstro
Mar 10, 2011 07:53 PM
johnson
Mar 6, 2008 09:52 AM
sante65
Nov 17, 2007 09:28 PM
Dietz589
Jan 16, 2006 08:36 PM
