engine mods?
Old Dec 18, 2007 | 12:07 AM
Gixxerkid's Avatar
Default engine mods?
Is it possible to put LS1 parts on any 350, or can they only be used with LS1 blocks?
Old Dec 18, 2007 | 12:15 PM
350rs's Avatar
March 2008 ROTM
Default RE: engine mods?
i think it depends on what parts. but for most, if not all, NO!
Old Dec 18, 2007 | 02:16 PM
Gixxerkid's Avatar
Hmmm. That sucks. I'm still trying to figure out why if you can't. LS1=small block 350.
Old Dec 18, 2007 | 02:41 PM
Look at them side by side and you will see why.
Old Dec 18, 2007 | 07:47 PM
Jr. Mechanic's Avatar
August 2009 ROTM
You can use LT-1 parts, the heads are a nice upgrade. I think the only other things you would need are center bolt valve covers (if you dont already have them) and self aligning roller rockers. But the guy that I bought my engine kit from told me that most 305/350's he has seen with lt1 heads have overheating issues so you would have to upgrade the cooling system...
Old Dec 19, 2007 | 02:09 AM
sewerrat's Avatar
If you are refering to the LT1 2gen sb heads, I don't think will work to well on a 1stgen sb because of the reverse cooling system. But if you are talking about the LT-1 found on the late 60s early 70s, these were bolted to 1st gen engines.
lillmulls
Sep 1, 2011 08:33 PM
EvansBlue
Nov 20, 2010 04:50 PM
WIspartan1026
Jul 4, 2009 10:55 PM
maroz2894
Jun 19, 2009 02:14 PM
drswitala
70-81 V6/I6 Tech
May 12, 2007 06:31 AM
