Engine idle problems
Old 09-05-2010, 09:55 PM
86CamaroZ28's Avatar
August 2010 ROTM
It's not the tach, the car does pull through the brakes, sometimes it's even hard to stop.. The throttle arm doesn't stick, and as for vacuum leaks; one of the vacuum hose is somewhat loose but it has a clamp on it. how would I be able to find other leaks?
Old 09-06-2010, 08:09 AM
blackz87's Avatar
Originally Posted by 86CamaroZ28
Alright... I put in a new IAC valve. reset the valve. and cleaned the mass air flow sensor.
Doesn't seem to have any affect on the problem. Maybe the MAF needs replaced?
Did you adjust the Idle at the thottle body after you installed the new IAC??? Also the Maf is NOT the problem.
Old 09-06-2010, 09:01 PM
August 2010 ROTM
I would adjust the idle, except that the idle is only high sometimes... it will idle around 600 rpms and then 10 minutes later, jump up to 2500. So not sure if it would screw it up? Do you think I should try it?
Old 09-07-2010, 07:11 PM
microkid's Avatar
March 2011 ROTM
Technical User
pull off the inlet to the throttle body and visually/physically inspect the throttle body butterflies. i know one of mine had a screw broken off, but it never gave me issues. im thinking maybe that has happened to you, but you are getting the butterfly stuck partially open
Old 09-07-2010, 07:17 PM
August 2010 ROTM
Hey, I had the throttle body inlet off the other day, I didn't really observe it too hard... But the throttle body is brand new, so it shouldn't have any physical damage.
Old 09-07-2010, 07:52 PM
August 2010 ROTM
ah ha, I hopefully just found the problem. The small vacuum line that comes off the bottom of the throttle body and runs to the firewall connector, is burnt in half... I'm going to replace it tomorrow, hopefully this will fix the idle!
Thanks for the help so far
Old 09-07-2010, 08:25 PM
microkid's Avatar
March 2011 ROTM
Technical User
there you go, it just may help it. if not, i would continue looking at the throttle body or the gasket to it. something funny may be happening in that area since its new
JGuy07
01-25-2012 06:57 PM
jcase350
82-92 V8 Tech
06-15-2010 08:05 PM
wils5150
06-10-2010 07:21 PM
lakeway motors
12-16-2008 07:18 PM
frankstuhler
06-21-2006 01:19 AM
Quick Reply: Engine idle problems
