Help...Idle Problems
Old Jun 15, 2010 | 08:05 PM
jcase350's Avatar
Default Help...Idle Problems
I have a 90 camaro Iroc w/ 350. The idle is surging up and down pretty bad and it likes to die and when I push on the gas the RPMs drop like it wants to die but as soon as they drop they come right back up and go. Is there a way to tell if the IAC motor is good or bad? Also, my Inflatable Restraint light is coming on. Would that mess with the car's performance? Doesn't do it all the time, sometimes it runs fine. Even at higher RPMs you can tell it's still surging a little. I just got done replacing the EGR Valve, Cap and rotor, TPS Sensor, coolant temp sensor, plug wires, plugs, fuel filter, and the ignition coil. Also, I just checked to voltage on the TPS sensor and it's reading .75 volts with the ignition on without it running....doesn't have anwhere on it to adjust that I can tell. Is that to high or should it be set right at .54 volts?? Help!!
B_Dubya
Oct 21, 2014 11:33 PM
BrianFol
Feb 5, 2013 06:39 PM
jcase350
Jul 18, 2010 05:22 PM
delta2ul
Dec 11, 2009 04:13 AM
Sodamhot
Oct 27, 2007 11:56 AM
