engine differences
Old Apr 17, 2007 | 08:50 PM
86whiteirocz28's Avatar
Default engine differences
my 86 irocz came with the 305 5.0 engine auto. i am looking for an engine now and i found a few. what would i need to do to make a 350 fit in my car? are the motor mounts the same? will the 350 engine mount up to auto tranny? what do i need to do to make the 350 fit period?
thanks
Peter
Old Apr 17, 2007 | 08:55 PM
350rs's Avatar
March 2008 ROTM
Default RE: engine differences
pretty much goes like this...
step one: remove 305
step two: put in 350...
its fits fine. same mounts, tranny bolts up. depending on what kind of injection you go with, it may require a new harness and ecm.
Old Apr 17, 2007 | 09:18 PM
it has the tuned port. what would happen if i carbed the motor. i dont need any of the harnesses and computer. but what about the tranny computer???
Old Apr 17, 2007 | 09:23 PM
uradumass5695's Avatar
Like 350 rs said.
Step one:remove 305
step two: insert 350
If your going from a tpi305 to a carb 350, then
Step 3:unplug ecm
Old Apr 17, 2007 | 09:25 PM
the tranny will still shift right with out the ecm. auto tranny
Old Apr 17, 2007 | 09:26 PM
350rs's Avatar
March 2008 ROTM
i believe youll still need the ecm for the tranny though. It may have its own computer, i dont remember. I have t-5 and didnt have to worry about it. THAT computer is in my head. Why not just stick to the TPI though? And if you are indeed switching it out. How much you want for ALL of it?
Old Apr 17, 2007 | 09:48 PM
i need alot of new sensors and stuff like that and idk if i want to go through all the trouble for it. so the carb would eliminate all of the sensors. ill let you know if i am going to sell the TPI. you have dibbs 350rs.
Old Apr 17, 2007 | 09:59 PM
350rs's Avatar
March 2008 ROTM
nice, thank you. lemme know when you know, ive been wanting to get rid of my TBI forever.
Old Apr 17, 2007 | 10:59 PM
gozzy341's Avatar
yeah man with chevy all you need to know is small block, and big block, all small blocks are the same size and all big blocks are the same size
small block- 305, 327, 350, 383, 400
big block- 396, 427, 454, 502
Old Apr 18, 2007 | 01:10 AM
ORIGINAL: gozzy341
thats some good info thanks
