E brake
Old Sep 26, 2007 | 10:54 PM
hurley870's Avatar
Default E brake
My e-brake dosent work. If I pull it all the way up it won't hold the car still, even on the smallest incline. My e-brake light is also stuck on. What's the problem here? Does it just need to be adjusted? Why would the light be stuck on? Thanks
Old Sep 26, 2007 | 11:39 PM
ScottD's Avatar
Default RE: E brake
Your cables are either frozen or broken. Search the subject here and you will find how to fix it. Not very complicated but you need some muscle. If you need anything else feel free to PM me-Scott
Old Sep 27, 2007 | 03:45 AM
MadMikeZ28's Avatar
Default RE: E brake
Rear brake linings need adjusted and/or replaced. And your ebrake light switch may be damaged or your brake balance is off or the wire from the proportioning valve may be grounding.
Old Sep 27, 2007 | 11:36 AM
hurley870's Avatar
Default RE: E brake
thanks guys i'm gonna check it out tomorrow when i get paid
Smittys_z28
Dec 24, 2014 02:14 PM
Willie Anderson
Dec 22, 2012 10:23 AM
XxCaMeLxxToSiSxX
Dec 8, 2010 11:27 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
tyler2497
Mar 10, 2007 03:35 AM
