dang hatch Wont close!
Old Feb 11, 2009 | 09:50 PM
a-dusty-camaro's Avatar
Default dang hatch Wont close!
My 1987 Iroc Z hatch wont close!
ive had this problem since i bought it, now its just annoying!
The striker wont even latch. and the motor i never hear so i dont even think it works idk..
I need help.
usually i just Slam it and use all my weght to close it. but i just put on black out tail light covers and i dont wont to break them...
Old Feb 11, 2009 | 11:50 PM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
pull off the plastic trim piece off of the inside rear and check your relay to see if it is broken. It will be a small black box plugged into some wires at the bottom. my trunk leaks a bit and shorts it out. If it is corroded or ruined you could tie a plastic bag around the new relay or wrap it in tape to keep water out.
If it is the motor instead of the relay you could always loosen the bolts and raise it up so it is easier to latch but I would check the relay first.
Old Feb 12, 2009 | 12:07 AM
jim022659's Avatar
and b4 loosening the latch to raise it, you might want to lube up the movable part of the latch itself. I had this issue and it turned out to be caused by corrosion. you can buy greas in a spray can that works great.
Old Feb 12, 2009 | 07:59 AM
blackz87's Avatar
If you are slaming it shut, I can say the pull down system is shot. Nothing short of replacing the Parts will make it work.
Parts needed:
1) Nylon guides
2) Dr Gear
3) Electric motor
4) Housing if needed
Parts can be found at TopDown Soultions and their web site has a excellent set of instructions that can be downloaded.
Old Feb 12, 2009 | 09:23 PM
Parts needed:
1) Nylon guides
2) Dr Gear
3) Electric motor
not necessarily. if his pull down was all the way down then he should be ok. the real problems come if it id up and someone slams it. then the slams down on it and smashes everything.
Old Feb 12, 2009 | 10:39 PM
9camaro1's Avatar
well mine had to do with the headlight switch not having the right power. i put power to it and the hatch worked.
PatKeenan
Sep 27, 2012 04:37 PM
baarf
Aug 14, 2010 09:12 PM
thebandit110
Sep 21, 2007 10:25 PM
91 Camaro RS
Dec 4, 2006 12:37 AM
