convert auto to 5 speed
Old Jan 30, 2008 | 10:28 PM
jml317's Avatar
Default convert auto to 5 speed
what all do i need to convert an aod automatic to a 5 speed in 1985 camaro?
Old Feb 1, 2008 | 03:22 AM
DoubbleQue's Avatar
Default RE: convert auto to 5 speed
I am not too sure, but i know my 1985 RS automatic was converted by the prev owner to a 5 speed.
I will look into it for you.
Old Feb 1, 2008 | 08:57 AM
Jr. Mechanic's Avatar
August 2009 ROTM
You would need a T-5 "world class" transmission from a V8 camaro, V8 bell housing, transmission cross member, drive shaft, clutch, flywheel, pedals, trim bezel, clutch slave cylinder, along with some other small things. It is a major pita to do if you just collect the parts, it isn't too bad however if you have a parts car with everything you need.
Old Feb 1, 2008 | 10:38 AM
350rs's Avatar
March 2008 ROTM
ORIGINAL: Jr. Mechanic
agreed 100%. Find yourself a parts car that has the 5 speed and get it. if you dont. might as well not do the swap. Unless you have LOTS of time to wait around.
MDThomas26
Apr 14, 2012 03:12 PM
jeff_blake
Jan 31, 2010 11:43 AM
jml317
82-92 V8 Tech
Jan 30, 2008 10:16 PM
31lilly
LS Series Tech
Mar 26, 2007 08:56 PM
XFaded
Dec 31, 2006 03:00 PM
