Clutch not working
Old Mar 14, 2006 | 05:29 PM
91camaro's Avatar
Default Clutch not working
I have a 91 camaro RS 3.1 V6 with a 5 speed manual. I just went through the process of replacing my clutch, pressure plate, and throwout bearing. After reassembling I tested it and my clutch will not disengage. I then took everything apart and confirmed that I had the throwout bearing installed correctly, and that the clutch master and slave cylinder are working. After assembling I then tried it again with the same results. I am stumped as to why the clutch will not disengage. Has anyone else had this problem? Please help.[:@]
Old Mar 16, 2006 | 02:17 PM
SickSickSick's Avatar
Default RE: Clutch not working
On Hydraulic Clutches, Most Of The Time The Problem Is Usually Air In The Lines. Bleed The Cylinders. Sick
Old Mar 19, 2006 | 08:06 PM
91camaro's Avatar
Problem found. The replacement clutch plate is just slightly different then the original. The clutch plate side that goes to the flywheel of the original is flush, while the new one slightly sticks out. When I returned it to the parts store they double checked everything, and we found that whoever packaged the clutch kit included the wrong clutch plate. They replaced the kit with the right parts and now everything is working correcly.
94ChevyCamaroV6
Jul 25, 2012 09:52 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Pro_built7
Apr 10, 2007 02:07 AM
