Clutch installation
Old May 16, 2007 | 05:45 PM
85z285.0's Avatar
Default Clutch installation
Hey gang I just picked up a Centerforce DualFriction clutch and Throwout Bearing from Jegs. I was wondering what advice, tool recommendations, or any insight you may have in the removal and installation of this clutch. All advice welcome thanks a million.
Old May 17, 2007 | 01:42 AM
1985RS's Avatar
Default RE: Clutch installation
well when your putting the clutch up, make sure you use the alignment tool that came with the clutch, and torque the pressure plate in sequence to avoid warpage, other than that, take your time, make sure you dont press the clutch pedal with the trans out, and dont drop the trans on yourself and all should be good
dogdog130
Jun 28, 2012 04:28 PM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
