Choke heater
Old Oct 1, 2008 | 03:12 PM
kyleag89's Avatar
Default Choke heater
Does anyone know what the choke heater is and how it functions? I believe it has somthing to do with the charging system. Thanks
Old Oct 1, 2008 | 08:30 PM
MadMikeZ28's Avatar
Default RE: Choke heater
Well if you have a factory carbed Camaro (82-87) and the choke light comes on it could very well be a charging system problem. When the alternater is putting out power it will energize the choke system. This way the choke will not warm up and open with only the key left on.
Old Oct 1, 2008 | 09:40 PM
kyleag89's Avatar
Well I have gone through everything and disconnected the choke system and the car holds a charge. If the choke system is hooked up the batt dies in 1 min.
Old Oct 1, 2008 | 11:05 PM
MadMikeZ28's Avatar
Hook it up and without the engine running, maybe try it both way with key on engine off and key off, check for power at the choke. Without it running there should be none. Maybe the choke relay fused inside and is stuck
Old Oct 5, 2008 | 10:27 PM
kyleag89's Avatar
Ok so I know I have a good alt, batt, and cables. I replaced the choke relay and now the car runs off the batt. Before it would die in less than one min. My problem is that the alt isn't charging. I know it is a good alt because I watched it on the testing machine at adavance. What causes the volt reg. to not charge?
Old Oct 6, 2008 | 01:38 AM
MadMikeZ28's Avatar
Do you have a fuseable link between the alternator and battery? Maybe on a jubction block by the battery. May be corroded inside. Tug on the links a little.
Without it running and key off hook a test light to the batt terminal or the alt and see if it lights. If not there is a short in the wire to the battery.
sebi1990
Oct 19, 2010 12:01 PM
kolski
82-92 V8 Tech
Aug 1, 2009 11:05 PM
dhighway
Jan 12, 2008 07:28 PM
cef2lion
May 18, 2007 01:45 PM
camarorz28
Dec 23, 2006 06:20 PM
