Car won't shut off
Car won't shut off
I have an 86 v6 2.8L automatic Camaro. I put the car in park and took the key out it and it kept running. It also is hard to shift gears. This all happened at the exact same time. I had to pull a fuse to shut it off. The car is like its stuck in the start position everything will turn on without the key in radio,wipers,etc. I started it today and let it run for a minute and it started overheating. I don't know if the overheating is related to the other two. But any help would be appreciated.
RE: Car won't shut off
check your ignition switch assembly down on the column, it might be loose and needing adjustment or even replacing. if this assembly gets out of adjustment , the rod from the key wont push the switch far enough to shut off the car or the accessories.
Did you get it solved? Hope so, because thats a long time to have a car just sitting there running, with no way of shutting it off! Just curious about how many days it takes before one has to pop the cap & fill up the tank again, after a car sits for 1 1/2 months on idle? [8D]
