Cant get a vacume bleed on new brake lines!
Old Dec 11, 2010 | 10:25 AM
ScottD's Avatar
Default Cant get a vacume bleed on new brake lines!
So after replacing my entire brake system on the new VW project and I cannot for the life of me get pedal pressure or fluid to the back cylinders. I tried all night with a vacuum bleeder and even resorted to a rubber hose and human power. Blech. No luck. Ive got fluid to the front 2 but no pedal pressure (probably because the entire rear circuit is dry). There are no leaks or other bleed valves that I can find. Should I try and pressure bleed it (hook up some cap to the master cylinder and hook a positive pressure source thru the system) This is pissing me off.....this shouldnt be this difficult!
Old Dec 11, 2010 | 11:22 AM
I don't know VW's very well but with older GM cars the conbination valve could detect a leak front to back and it would switch off Front/back and would require the mechanic to reset it. Second the bleeding proceedure varys depending on design some master cylinders require bench bleading because when mounts their angle will not allow air to get out.
I would bet you do have a combination of issues. Not being able to build any pressure (even pumping) would be concidered a major system failure on a GM car. These systems are designed so that no one failure of a wear item would cause complete loss of brakes.
Old Dec 11, 2010 | 12:40 PM
Air in the line compresses, fluid doesn't. That's why you're having a hard time with trying to push it through. Try cracking both rear bleeders open and let the fluid gravity feed out. If it doesn't want to go that way, then try pressure at the reservoir. And from what I remember from back in my V-Dub days, the brake system isn't all that sophisticated as far as having a resettable prop./combo valve.
Old Dec 11, 2010 | 10:04 PM
ScottD's Avatar
Nothing complicated....the donor chassis is a 67 Beetle. Just a master cylinder, brakes lines and pistons. Im gonna try again tomo.
Old Dec 12, 2010 | 03:53 PM
ScottD's Avatar
I took an air compressor and blew thru each section of line. cylinder to rear t was good....rear t to brake hoses was good. Brakes hoses to steel line.....wait a second.....both brake hoses looked good on the outside but are completely plugged on the inside. Guess Im off to Napa tomo.
jason7504
Nov 26, 2010 07:24 PM
mxskater56
Jan 4, 2008 01:31 AM
mike5908
Oct 7, 2007 03:57 PM
jonjon
Jul 27, 2007 04:27 PM
mattvogt
Jun 29, 2005 04:21 PM
