Can't bleed new brake caliper
Old Sep 29, 2007 | 04:18 PM
mike5908's Avatar
Default Can't bleed new brake caliper
I just replaced the two front calipers on '69. right side I was able to bleed left side - can't bleed
Old Sep 29, 2007 | 06:30 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: Can't bleed new brake caliper
I assume you have gotten the bleeder open, but no fluid came out. Check your lines, starting with the rubber hose. It is rare but I have seen hoses collapse and not let fluid through. Disconnect it from the caliper and press the pedal.
Old Oct 1, 2007 | 12:20 PM
Dman's Avatar
This may sound dumb but I have to ask anyway... On my 67RS the front calipers will inerchange from left to right are your bleeders facing up? Years ago I tried for weeks to try and bleed my system off with the bleeders facing down till some old timer brought it to my attention!! They must be facing up or the aircan get caught up in the caliper.
Old Oct 1, 2007 | 02:58 PM
MadMikeZ28's Avatar
A collapsed hosed can allow fluid through when the pedal is depressed. It will usualy not allow fluid to return causing the brakes to hold when the pedal is released.
Either leave the bleeder open until fluid comes out or have a helper open the bleeder while the other pushes on the pedal. Don't try to pump then open. Then close the bleeder before releasing the pedal. When you are alone a small plastic tubing from the bleeder into a jar of fluid works also.
Old Oct 7, 2007 | 03:57 PM
Blade's Avatar
June 2007 ROTM
need more info!!!!!!!!!!!!!!!!!
Zmaro
Jul 26, 2011 04:43 PM
ScottD
Dec 12, 2010 03:53 PM
eddiebj
Jul 9, 2008 01:16 PM
kaoss_11
Mar 7, 2008 10:44 AM
jonjon
Jul 27, 2007 04:27 PM
