A/C Questions
Old Jul 15, 2011 | 06:06 PM
rusty vango's Avatar
as long as you flush the system of old oil and you replace the o rings and the reciever dryer ,you should be good to go to use r-134-a good luck
Old Jul 15, 2011 | 06:48 PM
microkid's Avatar
March 2011 ROTM
Technical User
you got the bases covered. dryer needs changed, and needs to be held in a vac for 30 minutes to boil out the old oil. install new oil and refrigerant and be done. if theres a leak, it will be found when vacuumed down. best bet is to have a shop do it so if it does leak after its done, its on them for not finding it instead of it being your cost.
Old Jul 16, 2011 | 06:51 PM
jrdnrdg's Avatar
well i decided i would just gander at my a/c system before i brought it in monday after work found my sure leak. i took that little plastic cap off of the high pressure side of the system and what little r12 i have left came hissing out, the valve stem on the high pressure side is bad. im pretty happy that this may be the one and only leak and will only cost me a few bucks to fix. just thought id give you an update.
Warpig
Apr 20, 2009 09:33 PM
bigjsmashman
Feb 21, 2008 11:05 PM
nj93zkid
Feb 24, 2007 01:20 PM
dubbs95
Oct 21, 2006 01:29 PM
