A/c only blowes on the floor.
Old Jun 26, 2012 | 08:15 PM
1967hemigtx's Avatar
Default A/c only blowes on the floor.
Hello, I have a 1984 Z-28 Convertible. Everything looks stock except the stereo. I can't get the A/C to blow threw the vents on the dash. It only blowes on the floor but, it is cold. What is usually the problem?
Old Jun 27, 2012 | 12:55 PM
Is there anyone here?
Old Jun 27, 2012 | 12:57 PM
Old Jul 1, 2012 | 03:51 PM
microkid's Avatar
March 2011 ROTM
Technical User
what about heat settings? a lack of vacuum will default it to defrost. sounds like something is stuck inside the box
Old Jul 1, 2012 | 06:05 PM
djs383's Avatar
84 z28 convertible? I was under the impression that wasn't an available model unless done by an aftermarket firm. Not to sidetrack the original question....
Old Jul 2, 2012 | 01:56 PM
The A/c only blows on the floor. The car was converted by Auto Forms.
Old Jul 3, 2012 | 12:29 PM
torque_is_good's Avatar
when you mive the selector do you hear anything?
does defrost blow up top?
Old Jul 3, 2012 | 09:15 PM
I can move the selector but, it doesn't make any noises nor does it change anything. Tim
Old Jul 4, 2012 | 07:30 AM
you need to do a couple of things
first, remove the plastic cover by the passengers foot area so you can see what is going on
next, check the vacuum connection for hvac under the hood (good time to get a shop manual me thinks because it has all the diagrams)
reidski182
Oct 20, 2012 10:30 PM
thebandit110
May 24, 2009 05:09 PM
Kasnooze50
Feb 11, 2009 03:35 PM
red star
Feb 5, 2009 12:57 PM
77Camaro
Dec 13, 2006 05:48 PM
