bypass
Old Aug 5, 2007 | 06:40 AM
rancho2940's Avatar
Default bypass
Ineed help with bypassing key decoder module.
Sometime car wont start and if i wait 5 min, it starts like nothing happen.
I know its the lock or key[8D]
Old Aug 5, 2007 | 03:13 PM
camarohelp's Avatar
Default RE: bypass
I used to have the same problem.
The problem is, mine was already bypassed. Strange thing is, suddenly it started working no problem.
Anyway, there's an article:
http://www.thirdgen.org/vats
In my 92 Z28 there was an orange wire leading from the lock down the steering column, to a black clip. There's a number of ways to do it, but I think the easiest is to cut the orange wire a few inches above the clip, take off the orange sheath, strip the two smaller wires you'll find inside, and solder a resistor (with the same resistance as the one in your key) between the two wires.
Ask if you need more details.
87 camaro z28
Jan 22, 2013 04:46 PM
blackonred
Jul 3, 2011 09:49 AM
MI_camaro_98
May 7, 2008 09:57 PM
93Z28joel
Oct 28, 2007 10:43 PM
parker987654321
82-92 V8 Tech
Jul 17, 2007 04:59 PM
