brakes locking up?
Old Jun 1, 2006 | 04:22 PM
350rs's Avatar
March 2008 ROTM
Default brakes locking up?
When i first start up my car and get moveing in a parking lot or someplace where i dont get over 10mph, when i hit the brakes to slow down, it seems like i just SLAMMED on them. But as soon as i get over say 15 or 20mph, everything is fine. I have a 89 RS and the rear end has drum brakes. Whats the deal? Are they getting a little bit stuck? Wearing out? What? Im not gona lie, im not a car buff by any means, so i have NO idea what the problem could be. but it seems like the passenger side rear locks up when this is happening, espically if the ground is wet. Im not pushin the brakes hard or anything. Any ideas on whats wrong with this thing?
Old Jun 1, 2006 | 06:41 PM
SickSickSick's Avatar
Default RE: brakes locking up?
Several Things Could Be The Culprit. Are You Loosing Any Brake Fluid? If You Have Gotten Air In Your System It Can Cause Problems Like You Have Described. Sick
Old Jun 1, 2006 | 09:31 PM
350rs's Avatar
March 2008 ROTM
na, fluid levels are fine, but i guess i could bleed the lines anyway, it needs to be done, maybe there is indeed air in the line. Thanks.
Old Oct 31, 2006 | 12:04 AM
Goodfella's Avatar
I have the same exact problem. i was in a grocery store parking lot today and some poor guy nearly shat himself when he heard the rear lock up like that. and when i go like 5 mph and press the pedal they just lock up.. how did you fix your problem?
thanks man
Old Oct 31, 2006 | 12:21 AM
350rs's Avatar
March 2008 ROTM
i have drum brakes, i just sanded them down real good and the problem was completely solved. i dont know how, but im not gona complain about it i can tell ya that much.
Old Oct 31, 2006 | 11:22 AM
ScottD's Avatar
I dont know if my last post took.
Im betting 5 dollars you have a small leak in your brake piston. I had a Plymouth do this years ago to me, Id start the car, drive a few feet and the first time I hit the brake, the rear right would lock up. I tore her apart and found a small leak in the piston boot. Good luck.
Old Oct 31, 2006 | 11:45 AM
shnormo's Avatar
That would seem like a good place to start. If you suspect it is the brake adjuster, go in reverse to a considerable speed and then hit the brakes real hard to set the self adjuster.
Old Oct 31, 2006 | 01:38 PM
RSZ28SS's Avatar
i had some problems like that but it was my brake booster....
Old Oct 31, 2006 | 06:29 PM
ScottD's Avatar
Maybe its your flux capacitor. Oh wait, that was on my DeLorian. Then I fixed it and went back to the future!
Sorry, its Halloween, I have to be a wisea$$ Its the only Holiday that Im allowed to behave as I like and get away with it!
Old Nov 3, 2006 | 11:29 PM
FlufyTiger's Avatar
You could take it to Jiffy Lube and tell them you have a brake leak, and you'd like them to fix it by putting oil in the system, then call corporate and tell them you want your brakes replaced because some dolt put a petroleum product in your brake system. Worked for my stepdad in his Tacoma. Of course, the car won't be able to move, so you'll have to get it towed out of there.....
camarodude77
Dec 16, 2015 05:52 PM
soxsdad
70-81 V8 Tech
Aug 2, 2009 07:47 AM
The Banks
May 19, 2008 09:40 PM
michmar
82-92 V6 Tech
Sep 3, 2007 03:10 AM
danlint
Apr 7, 2007 01:30 AM
