boiling fuel need help
Old May 30, 2010 | 04:10 PM
AJ_2's Avatar
Default boiling fuel need help
I've had trouble with my Camaro since day one, it boils my fuel once it hits about 90 degrees outside, I've put a new tank, Magnaflow, and lowered the pipes but the fuel is still boiling, any advice on what to do?
Old May 30, 2010 | 06:51 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Where is it boiling? What year is you car, and is it carb, TPI, or TBI? Need a lot more info.
I had this issue with my 83. The fuel would boil and cause vapor lock. Turns out the stock fuel line was routed within 1/2" of the header. I rerouted the fuel line to the drivers side and along the K frame over to the fuel pump and haven't had a problem since.
Old May 30, 2010 | 08:53 PM
80ZJoe's Avatar
July 2010 ROTM
+1 More info.
crazykidsmoker
Mar 3, 2012 01:31 AM
Exterminex
Oct 11, 2009 10:21 AM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
