Another engine swap question.
Old Jan 25, 2011 | 10:05 AM
Spartan66's Avatar
I have a TBI. So what i am getting from all this is a 350 will drop right in and once i hook everything back up and get the computer to track the new engine itll be good to go? I dont have to worry about installing new motor mounts or anything like that?
Old Jan 25, 2011 | 01:51 PM
carguy68ssrs's Avatar
NOPE Everything will bolt right up. I have a 92RS, bought with locked up 305, went to Kragen and bought long-block 350 for Z28 of same year. Put all my parts on that motor and dropped it in. I changed NOTHING ELSE but the long block, same injectors,computer. Been driving it for 5 years as DD, NO engine problems.
Old Jan 25, 2011 | 08:26 PM
microkid's Avatar
March 2011 ROTM
Technical User
yes, everything will bolt up. the block they use is the later style 1 piece rear main seal, so your flexplate will work, and the balancer should also the be the same. i know with mine, i had to extend the wiring for my oil pressure switch about 6 inches as the oil port is on the side of the block instead of the top of the lifter valley. the mounts will all be the same. make sure you label them for driver and passenger as they are not side interchangable. everything else though will work except those previously stated
nevada
Oct 13, 2012 12:30 AM
je43278
May 25, 2010 06:05 AM
ElementSkater
Sep 22, 2009 05:05 AM
Z28nateZ28
Dec 22, 2007 12:55 PM
TheGirlNextDoor
Jul 31, 2007 09:32 PM
