LT1/LT4 Tech 1993-1997
Engine Swap.... Question?
Old Dec 3, 2007 | 04:22 PM
Z28nateZ28's Avatar
Default Engine Swap.... Question?
Ok so my friend has a '96 Z28 LT1, 6 Speed. He managed to blow his engine up so me being the "Car Guy" im going to rip his old engine out and put his new one in. Now he had an LT1 of course... So i went ahead and found him another LT1 out of a corvette. Now im just corious, is there anything i should know about swaping these out? Like any particularly difficult parts? They are identical engines so space wont be an issue. Any info would be great. Thanks
Old Dec 3, 2007 | 06:49 PM
Default RE: Engine Swap.... Question?
Basically the same, except for some plumbing, which you can transfer over from the old engine, The water pump may have different intake and outlet angles.
Old Dec 4, 2007 | 09:36 PM
Z28nateZ28's Avatar
Yeah that stuff shouldnt be to difficult. So basically its just going to be the connections (plumming, electric, fuel, etc.) Then basically just undo the motor mounts and rip that beezy out?
Oh and should i pull the trany out with it? then just put the new engine in tranny and all? Or would it be easier to just unbolt the tranny?.... Wait no that sounds more difficult. Ill jsut leave the tranny in.
Old Dec 10, 2007 | 04:30 PM
LT1RUNNER's Avatar
And dispite what you've heard about pulling the engine from the bottom is the only way. Not true. I pulled my engine out from the top. You may have to remove the ac condensor though.
Old Dec 22, 2007 | 12:55 PM
cdcamaro's Avatar
I just put a 383 in my camaro and removed my old engine and transmission from the bottom it went really well. This is a good site that might help.
http://www.michiganspeed.com/enginepull/index.html
nevada
Oct 13, 2012 12:30 AM
Spartan66
Jan 25, 2011 08:26 PM
je43278
May 25, 2010 06:05 AM
ElementSkater
Sep 22, 2009 05:05 AM
TheGirlNextDoor
Jul 31, 2007 09:32 PM
