Acceleration help needed.
Old Jul 21, 2011 | 05:23 PM
84bliss's Avatar
Default Acceleration help needed.
Hey guys, i have a 1984 Camaro Z28. it has a 350 small block and a 4 barrel carb. When i step on it it has about a .5 to 1 sec delay before it starts to fly. Is there anyway that i can fix that to where it will just get up and go from a dead stop?
Old Jul 21, 2011 | 07:02 PM
A good tune up, and a tune from someone that knows how to work with carbs will help.
Old Jul 21, 2011 | 07:04 PM
84bliss's Avatar
and that will take away all the hesitation that the engine has?
Old Jul 21, 2011 | 07:43 PM
It all depends what causes the hesitation. If plugs and spark timing are set properly, then the carb will have to be looked at, especially jetting and accelerator pump setting. That is, unless someone stuffed in a cam that is too big for street use.
Old Jul 23, 2011 | 12:39 PM
Stevolwevol's Avatar
Is your carb a metered quadrajet?
Tandyman
Sep 2, 2013 12:56 PM
bryon
82-92 V6 Tech
Dec 24, 2010 10:18 PM
redvsblue1981
Jun 15, 2010 02:11 PM
ReeceDawg
82-92 V6 Tech
12
Sep 14, 2007 04:42 PM
