AC Delete?
Old Jan 23, 2008 | 12:20 AM
pyrofire127's Avatar
Default AC Delete?
could anyone tell me what all has to be done to fully delete my AC?
What i know for sure is that i have no freon in the system, and it doesn't work anyways so why not make some extra room.
Thanks guys!!
Old Jan 23, 2008 | 07:05 AM
blackz87's Avatar
Default RE: AC Delete?
If you plan on keeping the car go for the A/C delete. However; any resale value is going to take a hit without the A/C.
Old Jan 23, 2008 | 08:41 AM
yeah i plan on keeping it. its resell has already gone to next to nothing with some of the other things anyways
Old Jan 23, 2008 | 09:03 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Just remove the compressor and the dryer and you should be alright.
Old Jan 23, 2008 | 09:43 AM
blackz87's Avatar
You will need the A/C delete pulley for your belt system. Also I do not know how it will affect your heat & defrost with the A/C removed.
Old Jan 23, 2008 | 11:47 AM
August 2009 ROTM
I see in your sig it says 350 swap, do you have V-belts or is it a serp belt system? If it is a V belt you should be able to just remove it, if not then what blackz87 said is correct.
Old Jan 23, 2008 | 01:33 PM
MadMikeZ28's Avatar
ORIGINAL: blackz87
The heat system will not be affected as long as he leaves the hvac box alone or replaces it with a non a/c one as the compressor is only used in the a/c or defrost positions. And the defrost will work like any other system without a/c......not as good.
Old Jan 23, 2008 | 03:38 PM
well the heater doesnt work either but yes its a serpentine belt so ill have to buy a new one
Thanks again guys!
Old Jan 24, 2008 | 12:04 PM
chadimus06's Avatar
they make belts that are shorter so that you can bypass the A/C compressor
Old Jan 24, 2008 | 12:55 PM
1969 SS's Avatar
why isn't your heat working?
