AC Delete?
could anyone tell me what all has to be done to fully delete my AC?
What i know for sure is that i have no freon in the system, and it doesn't work anyways so why not make some extra room. Thanks guys!! |
RE: AC Delete?
If you plan on keeping the car go for the A/C delete. However; any resale value is going to take a hit without the A/C.
RE: AC Delete?
yeah i plan on keeping it. its resell has already gone to next to nothing with some of the other things anyways
RE: AC Delete?
Just remove the compressor and the dryer and you should be alright.
RE: AC Delete?
You will need the A/C delete pulley for your belt system. Also I do not know how it will affect your heat & defrost with the A/C removed.
RE: AC Delete?
I see in your sig it says 350 swap, do you have V-belts or is it a serp belt system? If it is a V belt you should be able to just remove it, if not then what blackz87 said is correct.
RE: AC Delete?
ORIGINAL: blackz87 You will need the A/C delete pulley for your belt system. Also I do not know how it will affect your heat & defrost with the A/C removed. |
RE: AC Delete?
well the heater doesnt work either :) but yes its a serpentine belt so ill have to buy a new one
Thanks again guys! |
RE: AC Delete?
they make belts that are shorter so that you can bypass the A/C compressor
RE: AC Delete?
why isn't your heat working?
