92 Camaro v6 Problem
Hi Guy's I Am New Here. My 1992 Camaro RS Has The 3.1v6 And The Problem Is When I Go To Take Out From A Stop It Drops Out And Then Takes Out. It's Like A (Skip)... I Cleaned Out The Throttle Body And Have Ran Inj. Cleaner Thru It A Few Times But Does Not Help... Thanks For Your Help, Rob
1st thing I would do is tune it up (plugs, wires, cap and rotor) Use AC Delco not aftermarket stuff. If that doesn't help or fix it, next I would check the resistance of all the fuel injectors. These engines are terrible about them. They should all range between 11.5 to 12.5. If any different, replace them or they could leave you stranded on the side of them road soon, and again dont use aftermarket injectors, there is a thread in the V6 tech section of this forum about this
