92 camaro steering problem
Old Dec 21, 2008 | 02:00 PM
92rs343's Avatar
Default 92 camaro steering problem
I just bought a 1992 camaro rs and yes it needs some work. I do have a small steering problem though..when the car is going straigt the steering wheel is crooked??what causes this to happen?? It gets really annoying while driving..
Old Dec 21, 2008 | 03:23 PM
Default RE: 92 camaro steering problem
Very common, but easy fix. Make sure the tires are properly inflated and of the same size, then just get the wheels aligned at a good shop. The car may even handle much better after the alignment.
Old Dec 28, 2008 | 03:45 PM
91_Camaro_RS's Avatar
I agree with pete but if that doesn't work you can always just pull the airbag off the steering wheel (very easy) and make sure the wheel mark is lined up with the one on the stem. Who knows maybe the guy before you was messing around with the column and didn't put the wheel back on properly.
camaroguy92
Jul 13, 2015 10:08 AM
GoofieJ21
Nov 4, 2009 04:00 PM
nonrestorer
Feb 13, 2008 03:55 PM
luvmysccamaro
Nov 22, 2007 11:22 AM
Jaguar543
Oct 27, 2006 02:15 AM
