92 camaro door hinges
Old 01-14-2007 | 02:22 AM
b1keslddr's Avatar
Default 92 camaro door hinges
hey do you guys know where i can get a set of replacement or upgraded door hinges for my 92. i would like to get the doors to close right and hang right. i know they are heavy doors but if i replace the hingeswont that help?
Old 01-14-2007 | 02:47 AM
uncle bill's Avatar
Default RE: 92 camaro door hinges
Just replace the bushings, thats what wears out.
Old 01-14-2007 | 02:51 AM
b1keslddr's Avatar
who sells them
Old 01-14-2007 | 10:15 PM
MadMikeZ28's Avatar
The upper hinges are permant rivets. Either drillout the spot welds and replace the hinge or there is a guy that makes shoulder bolts and bushings to repair the hinges and he also sells the lower pin and bushing with it. You can do a web search and I will search for my reciept and get his number.
Here is a link to the kit. I acctualy got mine from the person who manufactures the bolts. I'll keep looking for his.
http://www.top-downsolutions.com/pro...products_id=38
Old 01-15-2007 | 01:42 AM
Tacos Z's Avatar
I was looking at mine, and on the lower hinge it looks like the problem is something that looks like a bearing or something that rolls along the door-check. I was curious if anyone knows where I could just buy that.. When I get home Ill take a picture, but at the moment Im out of town.
Old 01-15-2007 | 01:49 AM
ghotachevy's Avatar
napa
Old 01-15-2007 | 09:20 PM
MadMikeZ28's Avatar
The lower pins and bushing I believe are the same as S10s. You can get those pins and bushings in a kit just about anywhere in the "HELP" section.
NJZ28
06-12-2011 01:13 AM
sunfire
04-22-2010 07:30 PM
edogg
10-27-2009 11:18 PM
sPaC31
03-24-2008 06:18 PM
Quick Reply: 92 camaro door hinges
