91 rs suspension question
Old Aug 14, 2010 | 12:46 AM
towtruckman's Avatar
Default 91 rs suspension question
I just bought a 91 rs v8 5spd it scrapes on every thing, small pot holes even crossing over the crown of the road unless I go really slow. Is that normal for these with the ground effects? I thought I may need to change out the springs any thoughts? I have read that the Z28 in 91 had an upgraded suspension what is the difference between the RS and Z28 just springs and sway bars?? Can I swap the Z28 parts from the wrecking yard into my RS.
Old Aug 14, 2010 | 07:59 AM
blackz87's Avatar
You have 19year old car and you want to swap in another old car parts. Your best bet is to upgade your front Struts & rear shocks as a start and then go to new springs if you are stiill low. However; to answer your question...Yes, you can swap the parts from Z28 to a RS. Only difference was the spring weight & swaybar size.
Old Aug 14, 2010 | 08:44 AM
The main thing my old 91 RS (with 120k miles) would bottom out in the front was a driveway having a high angle of approach. Take the car up and in at an angle, not straight in, and it clears just fine. And it didn't clear some parking curbs either. But I didn't consider my suspension to be sagging, or sitting too low. You might want to look at pictures of ones online to compare a stock stance to a lowered one. If you're scraping on anything higher than a pebble, there is a possibility that some previous owner lowered your car. That, or your roads just plain suck.
Old Aug 14, 2010 | 12:11 PM
Great thanks yep I have been learning about driveways. I have owned 1 ton trucks for years I could roll over any thing now I need to look out for all this small stuff. One of the guys at work said he had a camaro like this and the hieght looks right, so I will start with the shocks and struts. I am in oregon so yes the roads suck! but i feel there are other issues to. Thank you for the advice ans information.
Old Aug 16, 2010 | 12:58 PM
doug91rs's Avatar
if its saggin bad u need springs with the shocks n struts go to p-s-t.com they have replacement after market springs shocks n struts for very cheap
CountTripula
Dec 19, 2014 09:16 AM
JPrice
May 20, 2012 03:48 PM
resahcluos
Nov 9, 2011 06:21 PM
demonic_outlaw
Sep 27, 2009 07:12 PM
85z285.0
Apr 11, 2007 11:38 PM
