91 brakes
Old Nov 7, 2006 | 02:07 PM
91_camaro's Avatar
Default 91 brakes
Is there anything I need to know about special tools or anything at all before I change the front brake pads on my 91 rs? Thanx
Old Nov 7, 2006 | 02:29 PM
shnormo's Avatar
Default RE: 91 brakes
3/8 Allen wrench. C clamp
Old Nov 7, 2006 | 03:41 PM
FlufyTiger's Avatar
Make sure it's at least a 4 inch c clamp, 6 inch would be better. You know what to use it for, right? Also, make sure to break the pads in properly, if the pads don't come with instructions, 30 moderate stops from 30 mph with 30 seconds between them is the generally accepted method, and seems to be pretty effective.
Old Nov 7, 2006 | 10:57 PM
91_camaro's Avatar
Thanx yeah I know what the c-clamps for. Thanks for the break in to. God I love this site. Thank u 4 being here for us "less camaro knowledgeable" people. Thanks again.
Old Nov 8, 2006 | 12:31 AM
FlufyTiger's Avatar
Just be sure to pass it along. There'll be many more after you who need this information later on, and now that you have it, passing it along is the best way to thank us for the information we have bestowed upon you.
Old Nov 10, 2006 | 02:25 AM
91_camaro's Avatar
Yeah will do.
Old Nov 10, 2006 | 04:30 AM
MadMikeZ28's Avatar
Does no one here ever lube the caliper bolts and the sleeves or the area where the calipers slide on the spindles???
You should have lube along with your tools
Old Nov 10, 2006 | 01:26 PM
FlufyTiger's Avatar
Actually, yes, I do, but it's such a habit that I don't even think about it. I've got a tube of caliper pin lube in the stuff boxes on top of my toolbox for just that reason.
camarodude77
Dec 16, 2015 05:52 PM
osduck5
Jun 12, 2009 08:47 PM
importmd
Mar 17, 2008 09:43 PM
92camaroRS
Jun 1, 2007 09:31 PM
coprunr
May 16, 2007 04:40 PM
