89 Iroc Z sat 6 months now no power steering
Old Jan 24, 2014 | 04:02 PM
c4maro's Avatar
Default 89 Iroc Z sat 6 months now no power steering
Wtfack. Is there any diagnostics I can do to see if I need a new pump?
Can i install int myself? what weird things would i have to know b4 doing so?
Damn its been a while, love this forum.
5.7L stock
Old Jan 24, 2014 | 04:07 PM
c4maro's Avatar
No whining sounds
Old Jan 24, 2014 | 06:00 PM
To get the obvious things out of the way.... is the belt to the pump still there? Have you checked the fluid level in the reservoir?
Old Jan 24, 2014 | 08:49 PM
c4maro's Avatar
yes yes. can i just take it off and take it apart, clean it and see if that fixes it. just a stuck valve or something?
Old Jan 24, 2014 | 08:51 PM
c4maro's Avatar
And damn I remember you. I wonder how much money you've saved people over all these years in total with your advice? Good man.
Old Jan 24, 2014 | 10:36 PM
Where are you located? It's strange that the p.s. worked when parked, and not now after sitting six months. If perhaps you got moisture in the fluid that settled in a line, and then froze, that could do it. If you're somewhere warm though, there goes that thought.
Old Jan 24, 2014 | 11:06 PM
c4maro's Avatar
Vancouver canada
that sounds like a possibility i guess but my 87 z28 was parked right behind it for the same time and works fine.
am i going to through off adjustments if i go ahead and take it off and try and clean it or replace it?
Old Jan 28, 2014 | 07:24 AM
c4maro's Avatar
bump
Old Jan 28, 2014 | 07:50 AM
You won't throw off any adjustments (assuming you're referring to alignment) by removing the pump and/or steering box. But before doing anything that drastic, I would first get the car in a warm garage, let it heat up a while, siphon out or flush the old p.s. fluid, and put in new. Moisture, inactivity, and freezing temps can cause problems that you may otherwise not have when warm.
royrois
Feb 15, 2013 02:28 PM
grabbem88
Jul 27, 2011 08:33 PM
94z28chevy
Jan 1, 2010 06:45 PM
The Banks
Sep 26, 2007 07:36 PM
MRSANTOS
Jun 26, 2006 12:29 AM
