85 IROC, SHOULD HAVE MORE POWER?
Old Jun 25, 2006 | 04:57 PM
MRSANTOS's Avatar
Default 85 IROC, SHOULD HAVE MORE POWER?
85 IROC Z28, Block Less than 10K miles, newly rebuilt 350 heads installed
fuel tank new, fuel pump new, fuel filter new.
Timing has been adjusted by local mechanic
Once in a while I have a slight backfire and the car just doesn't seem to have the get up and go I think it should.
Does anyone have any ideas on what I can check next? So I can get this car runnning like it should?
Spent alot of money the last two years getting her looking good and really want it to have some HP.
Hope someone can help me. Thanks
Old Jun 25, 2006 | 08:07 PM
SickSickSick's Avatar
Default RE: 85 IROC, SHOULD HAVE MORE POWER?
it's probably running too lean. starving for fuel. is it carbed or TPI? has the block been bored? are the valves stock?sick
Old Jun 26, 2006 | 12:29 AM
MRSANTOS's Avatar
The Engine is TPI, the block has not been bored and the valves are stock.
Never had the injectors cleaned the properly and they are original injectors. Is that something I should look into?
Dont know if a new set of injectors are the answer, Don't mind investing in a new set if that will take care of the problem.
Thanks for the reply
c4maro
Jan 28, 2014 07:50 AM
MaxTheKiing
Aug 23, 2010 03:21 AM
FearThisInc
Oct 9, 2008 11:17 AM
CamaroRS23
Jul 6, 2007 07:31 PM
