86 iroc hesitation
86 iroc hesitation
The car has hesitation during take off wether driving or in park have done full tune up problem still occurs. When u try to power brake u hear a popping noise through the intake has a new MAF PLUGS WIRES timing has been reset to factory and sometimes during starting u have to put your foot on the gas but when started stays running
RE: 86 iroc hesitation
Still it sounds like a fuel problem. could be dirty injectors, run a tank of premium fuel with half a quart of tranny fluid in it ( the detergent and anti sludge solvents will clean carbon and junk out of your injectors). If that does not work bring it on.
If it is carburated, and a Q-jet, reset your idle speed, you will have to drill the little cover off to get at the adjuster. Also check how fast your secondary air flaps are opening ( I know thats not the right "term" but it has been a long time since i have touched a q-jet.) If you have 160 bucks laying around, just order a 600 cfm remanufactured edelbrock from JEGS and be done with it.**EDIT** MAF means its Feul injected, but I will leave this hear incase it helps someone else who finds this article on google**EDIT**
it also could be your valve lash, maybe some of your rockers are too loose, but thats the next step once you know for sure your fuel system is good.
1986, 86, 87, camaro, car, differential, hesitates, hesitating, hesitation, hessitates, iroc, issues, leak, slight
