700R4
No it doesn't. It has a throttle valve (TV) which operates the kickdown/shifting function as well as fluid pressure in the trans. The TV cable is attached to the throttle linkage, and accurate adjustment is crucial.
ok well theres a hose under the hood rt side of intake thats runs downward towards manifold then turns into a steel line then runs back along the exhaust ..... it is disconnected and final length put it about at the pan ...... reason for my original question since i lost third gear thought it might have something to do with it ..... but looks like there's just an overhaul in my future
