400 bored .060
Old Mar 17, 2011 | 11:48 AM
Filthy McNasty's Avatar
Default 400 bored .060
Ok guys I just got my paper work form the engine builder.Here's some of the info .Tell me what you think.Bored 400 .060 over and ck 10 hone.Boiled block ,cam bearing freeze plugs.Cut block decks square .025.Balanced complete engine assembly.pressed pistons on connecting rods.Fly cut pistons. Clearance rods for cam.Roller chain & gear cam button.Machined 210 Procomp 64cc heads for steam holes.Weld drive rod oil pump.Checked and set clearances and assembled motor.CR 10.84.1 Howard cam retro fit roller 234/242@.050,294/302 adv. duration,.533"/.548",112+4 L/C with 1.5 roller rockers.Holley stealth ram with 58mm throttle body.
Old Mar 17, 2011 | 05:24 PM
torque_is_good's Avatar
I'll give you $200 for it.
pictures would be great
Old Mar 17, 2011 | 05:40 PM
You've got jokes.
Old Mar 17, 2011 | 07:09 PM
Originally Posted by Filthy McNasty
You've got jokes.
hey, you don't like my generous offer????
Seriously, 350's are common. You need to post pics of the 400 build. Yes it's a small block but you're doing it right with the machine work.
Old Mar 17, 2011 | 09:08 PM
junior.davilar's Avatar
Yea diff. put some pics.
Old Mar 18, 2011 | 09:47 AM
I am concerned about a 0.060" overbore. This is cutting pretty deep into the cylinder walls. The 400 cu inch block is not all that strong to start with.
shaggy
82-92 V8 Tech
Mar 25, 2014 03:13 AM
Camaro_Kid_LT_78
Feb 9, 2012 09:56 PM
94CamaroSFI
Oct 14, 2006 04:00 PM
