Igntion Problem Questions
Old Mar 16, 2011 | 07:33 PM
pimp2303's Avatar
Default Igntion Problem Questions
I have a 87 Camaro that i bought from a guy a while back and it has a start button isntalled. I want to remove it but the guy had it installed because when he turn the key, nothing happens. What could be the problem. Could this be the Ignition Module went bad. Not sure where to start looking. Any help would be appreciated.
Old Mar 18, 2011 | 06:25 PM
gfrench's Avatar
Strangely, it could simply be the key switch. I have a second gen that I installed a push button into because nothing happened when I turned the key switch.
A few months later I replaced the key switch because it was wore out. I noticed one day that the ignition wire was once again hot.
Try replacing the key switch. They are cheep. Then you just need to figure out what wire is hot only when the key is turned to the start position. On my 78 the wire is purple. Take that wire and run it to the starter solenoid.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
JaySan
Oct 23, 2006 04:48 PM
2lucke4u
Sep 1, 2006 09:55 PM
