305 tpi swap to 383stroker carb.
Old 08-15-2010, 08:59 PM
IROCZRickyBobby's Avatar
Ok guys I went ahead and bought the complete vehicle for 2500 just so everything would be easier I have one issue that I am worried about. The tail shafts are different.
There is no mounting bolts for the torque bar thing that goes to the axle
Is this a nessary componet?
if so....
Would it be easy to find a different driveshaft that I can swap in...if so which one?
Or do I have to take the transmission apart and change the tailshafts?
Old 08-15-2010, 09:34 PM
80ZJoe's Avatar
July 2010 ROTM
sorry to go off topic, i just had to comment on the screen name lol, do you wake up and **** excellence too lol.
carry on.
Old 08-15-2010, 09:51 PM
carry on.
Yeah...I didn't choose that name , but it stuck!
I do love to drive and I am funny as hell(goofy)
-Rick
Old 08-15-2010, 10:02 PM
80ZJoe's Avatar
July 2010 ROTM
Lol, it's just funny cause a my friend calls me Ricky Bobby. If your not first your last
Old 08-19-2010, 11:30 PM
Update:
Getting ready to pull the engine and transmission from the camaro...
Turns out that I don't have a 383...:-(
it is in fact a 400sbc to 406
I took the valve cover off and noticed that it had some ****ty roller lifters maybe from some other stock motor(lt1?)
I will be changing the front shocks ,sway bar links,wires,tires and anything else I can find
One ? is the engine wiring easy to pull out without effecting the ac wiring alt. wiring?
Thanks
Old 08-19-2010, 11:35 PM
You thought you had a 383 but it's a 406. Why the frowny face then?
Old 08-20-2010, 10:00 AM
80ZJoe's Avatar
July 2010 ROTM
^^ yeah really, i would be happier lol. check the crank #'s maybe you have a destroker on your hands?
Old 08-20-2010, 06:52 PM
microkid's Avatar
March 2011 ROTM
Technical User
just carefully disassemble the factory wiring and leave what you need behind. i take it you are running carb? if so, just swap the wiring harness over from another carb or tbi car. you could make about $500 selling the tpi intake, ecm, and wiring harness all together
Old 08-29-2010, 11:35 AM
Ok update....
I have the car almost complete with an exception of exhaust from the cats to the rear.
I installed a electric fuel pump and removed the old one.
I also removed the tpi wiring harness and it wasn't as hard as I was thinking I didn't have to cut any wires
(I will sell the entire setup for $300 includes the ecu which I don't know the condition but it says its remanufactered)
I am a little frustrated because the performance seems not as good as it was in the donor car which was 5200 lbs
I think it could be due to the wires or plugs so I plan on changing them...
I don't know what cam I have, but it is really lumpy
Where should I aim for in reguards to timing?
I'm at 12 btc
thanks
-Rick
Ps I'm in need of a rear Iroc rim if anyone knows of one..
  #20
Old 08-31-2010, 10:58 PM
Ok need some advice!
After driving my ride for 15 minutes or so starts to die like its running out of gas, if I turn it off for a minute it will restart after priming the pump!
I thought the pump was bad so I changed it...with the same results!
Could it be the carb?
That guy helping istalled the dist. 180 backwards so it did backfire a couple of times until I figured it out!
Let me know what you think! I will be buying a accel coil and new plugs tommorrow for it!
thanks!
NapolitanoZ28
05-22-2011 11:11 PM
jjusseaume
09-02-2010 06:50 AM
theFLoYD1964
82-92 V8 Tech
10-21-2007 11:32 PM
Auji350
82-92 V8 Tech
09-05-2007 07:36 PM
STANMAN
VS
20
05-22-2006 04:33 PM
Quick Reply: 305 tpi swap to 383stroker carb.
