305 Buildup
Old Mar 7, 2007 | 12:59 PM
  #31
350DREAMS's Avatar
Default RE: 305 Buildup
if not some hydraulic cams/rocker arms/ the smear, also edelbrock has a full top end kit for like 1600. i beleive.. other than that intake manifold. and headers if u wanna stay cheap.
Old Mar 7, 2007 | 02:00 PM
  #32
Celticsfan's Avatar
Thanks, but I think im gonna go with what microkid said and upgrade the valvetrain and throttle body etc...
any insight about the valvetrain stuff would be great, know nothing about them, i think ive found a twin 52mm tb from summit...
Old Mar 7, 2007 | 05:32 PM
  #33
hurley870's Avatar
My buddy's got a 90' Vette with a 350 TPI pushing around 325 HP and makes about the same gas mileage as me, maybe a littlebetter and I have a 305 TBI. Just a thought.
Old Mar 7, 2007 | 07:48 PM
  #34
digiti's Avatar
ORIGINAL: hurley870
I'd have to see it to believe it.
Old Mar 7, 2007 | 08:48 PM
  #35
microkid's Avatar
March 2011 ROTM
Technical User
cam: lunati voo doo http://www.jegs.com/webapp/wcs/store...6547_-1_313038
throttle body: http://www.jegs.com/webapp/wcs/store...50758_-1_11175
i cant help you with the rest of the valve train parts, i dont know much about them for this car for the required size. im sure someone else here can help
airfoil: http://www.jegs.com/webapp/wcs/store...52203_-1_11175
i also suggest an adjustable fuel pressure regulator: http://www.jegs.com/webapp/wcs/store...61135_-1_11175
jegs has a great selection on tpi parts listing, and a lot more listed elsewhere. i found all the parts by ordering a catalog and just going through the whole thing. http://www.jegs.com/webapp/wcs/store...11175_-1_10015
and for siamesing the ports: http://sethirdgen.org/TPIbase.htm
theres also a few summer time things that can help, like a throttle body bypass. thats a cheap $5 hose and fitting, and takes 20 minutes to do for about 5 hp. just read through the articles on these websites:
http://sethirdgen.org/trd.htm
http://www.thirdgen.org/technical-articles
Old Mar 8, 2007 | 12:49 AM
  #36
Celticsfan's Avatar
ORIGINAL: microkid
Thanks bro I appreciate all the information you have given me! I usually look at summit it just seems like jegs is set up weird, i will order that catalog! I assume the cam in the link is a mild cam nothing to crazy?
Thanks!
Old Mar 8, 2007 | 02:10 AM
  #37
hurley870's Avatar
ORIGINAL: digiti
He makes about 25 mpg highway. He bought the block from Jasper and we put it together. He added some mods, not sure exactly what, I can find out if you want. But it's got a little over 300 horses maybe not 325 exact and still makes decent gas mileage. Tuned ports manage fuel a lot better than the TBIs. If your around PA we'd be happy to show you.
http://www.youtube.com/watch?v=9jCFdJtM7wA
Old Mar 8, 2007 | 02:42 AM
  #38
MadMikeZ28's Avatar
ORIGINAL: digiti
ORIGINAL: hurley870
More HP will get better milage because its pulling easier than the car with the less HP. When you take off from a light with your V* and there is an old four banger next to you who do you think is pressing harder on the gas pedal to achieve the same speed.
Old Mar 8, 2007 | 04:34 AM
  #39
vanilla sky's Avatar
ORIGINAL: MadMikeZ28
I'm going to have to both agree and disagree. I'll explain.
V8:
pros:
1. takes little throttle to move the car
2. can be choked down to get better econ.
cons:
1. when you step on it, you can watch your fuel needle drop
4cyl:
pros:
1. good overal drivability
2. not a whole lot of power to be had. There's enough for what the car is designed for, though
3. get the cars both up on the highway and see what's going on. My Honda can get nearly 40MPG running 80MPH.
cons:
1: leadfoot kills econ, and is usually required for passing fast traffic or merging
2: not much reserve power on tap. There's enough for what the car is designed for, but some people don't find it to be enough.
For pure econ, I'll buy an older civic CX or VX. 50MPG, no fancy hybrids or anything. For pure power, I want some *****.
I have a lot of research to do when I start my buildup. I'm thinking about a swap, but I don't want something as thirsty as a 350. I need to pick up some reading material and learn what I can build with various longblock combonations.
Derick
Old Mar 8, 2007 | 05:01 PM
  #40
MadMikeZ28's Avatar
There are a lot more pros' and cons' you missed. All I was trying to accomplish was an easy explain as to why more HP does not always mean less MPG.
