1991 Camaro RS V6 3.1L (Overheat)
Old Sep 8, 2012 | 09:16 AM
Jarrell McGruder's Avatar
Default 1991 Camaro RS V6 3.1L (Overheat)
Yesterday my car overheated so badly that my car started to make a whistling noise(like a teapot) then i smelled gas and my car shut off...and i could barely get it to crank after that i had to let it sit for an 1hr and half before i could move it..What is going on?
Old Sep 8, 2012 | 10:10 AM
Sounds like you messed up your engine. Overheating can cause all sorts of bad things to happen, like warped heads, blown gaskets, poor lubrication leading to spun bearings, etc.. Your car has a temperature gauge, but have you ever looked at it or cared about what the temperature was.
Old Sep 8, 2012 | 12:42 PM
I always check the temp gauge...but the car isnt smoking...knocking or ticking
Old Sep 10, 2012 | 02:59 PM
mxr81999's Avatar
Just because the obvious signs arent there doesnt mean **** aint broke. Best bet would be to not drive it and do a heavy inspection on the heads, radiator, and other "top end" components. Maybe you can trouble shoot for a vapor lock issue. I dont know this engine very well, so if anyone else has any better advice, take it first. I'm just saying what I would start out with.
Old Sep 13, 2012 | 01:48 AM
Chuck_Jones's Avatar
I have the same problem with my 91 maro, I replaced the radiator & thermostat, and it doesnt overheat really anymore but when im stuck in traffic it tends to climb up a bit any help?
Old Sep 13, 2012 | 08:43 AM
The cooling fan turns on/is supposed to turn on when the engine hits 228 degrees. Having the temperature climb up a bit in traffic is perfectly normal. Having the gauge read past 230-ish isn't.
Tree_toflee
Jun 23, 2015 10:47 AM
Schuy69
May 17, 2011 10:51 AM
H2C
Feb 23, 2011 08:37 PM
born2ride
Feb 16, 2009 06:51 PM
Chevy101
Aug 5, 2008 08:23 PM
