1990 camaro need help!!!!
Old Dec 12, 2005 | 09:05 PM
Greathouse's Avatar
Default 1990 camaro need help!!!!
it cranks fine. when you are going down the road and you start to turn and apply your brakes it tries to go dead and even sometimes does go dead. replaced sparke plug wires, distributor cap, pvc valve. Does anyone have a clue what it could be? Its a V6 3.1 . HELP!!!!!!!!!!
Old Dec 13, 2005 | 08:10 AM
Lee Willis's Avatar
Default RE: 1990 camaro need help!!!!
Check your vaccuum hoses carefully and the power braker booster for leaks.
Old Dec 15, 2005 | 02:11 PM
RatedZ's Avatar
If you have an automatic, it may be your TCC (Torque Converter Clutch) Solenoid. When it's going bad, sometimes when you slow down your car will cut out because of the way the clutches in your transmission disengage.
Old Dec 15, 2005 | 06:08 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
i was actually doing to suggest the TCC soleniod, i just did one on my brothers Z-24
Old Dec 15, 2005 | 08:17 PM
RatedZ's Avatar
ORIGINAL: nj85z28
My dad had a TCC go bad on his old 92 GP, and it wreaked havoc on the operation of his car. It got to the point that the car wouldn't even start.
I can't remember how much it cost, but it might have been around $200-$300 for the entire job. I'm not familiar with transmissions, so I wouldn't even know where it's located.[:-]
Old Dec 15, 2005 | 09:15 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
on the Z-24, all i had to do was remove the drivers side tire and part of the wheel well, take off the side tranny pan and it was two wires that hooked up ina watertight connector. took a total of 20 minutes.
roomforblues
Jun 23, 2010 11:21 AM
3.4CamaroCDOG
82-92 V8 Tech
Feb 6, 2008 06:59 AM
CCarRocks
82-92 V8 Tech
10
Nov 9, 2007 09:57 AM
1990 Camaro RS
82-92 V8 Tech
Jul 1, 2007 02:20 AM
p3313r
Apr 13, 2007 02:36 PM
