1990 camaro need help!!!!
it cranks fine. when you are going down the road and you start to turn and apply your brakes it tries to go dead and even sometimes does go dead. replaced sparke plug wires, distributor cap, pvc valve. Does anyone have a clue what it could be? Its a V6 3.1 . HELP!!!!!!!!!!
RE: 1990 camaro need help!!!!
Check your vaccuum hoses carefully and the power braker booster for leaks.
If you have an automatic, it may be your TCC (Torque Converter Clutch) Solenoid. When it's going bad, sometimes when you slow down your car will cut out because of the way the clutches in your transmission disengage.
i was actually doing to suggest the TCC soleniod, i just did one on my brothers Z-24
ORIGINAL: nj85z28 i was actually doing to suggest the TCC soleniod, i just did one on my brothers Z-24 I can't remember how much it cost, but it might have been around $200-$300 for the entire job. I'm not familiar with transmissions, so I wouldn't even know where it's located.[:-] |
on the Z-24, all i had to do was remove the drivers side tire and part of the wheel well, take off the side tranny pan and it was two wires that hooked up ina watertight connector. took a total of 20 minutes.
