1988 camaro wiring problem
Old Apr 23, 2012 | 02:37 PM
torque_is_good's Avatar
on the '89 I had (305) the coil was separate. Do you have spark coming from the coil?
Old Apr 23, 2012 | 03:14 PM
I still think you have a short somewhere, either present or waiting to strike on you....again
Connect a test meter to the + terminal of the coil and see if you have 12 volts there.
Your coil could also have taken a crap. Or, if you had a serious short (the one that blew the fusible link), you could have toasted the ignition module that's inside the distributor.
Old Apr 23, 2012 | 03:38 PM
Jon ousley's Avatar
I'm not sure. How do I check?
Old Apr 23, 2012 | 03:41 PM
Jon ousley's Avatar
I'll check to see if I'm getting anything and I'll check the ignition control module. How do I know if the ignition control module is bad
Old Apr 23, 2012 | 04:01 PM
The first test would be to check for spark at your spark plugs/wires. If nothing, then the next test is to replace the ignition module. This is assuming you have power going into, and coming out of the coil.
Old Apr 23, 2012 | 05:22 PM
Jon ousley's Avatar
How do you check for spark at the wire and plug?
Old Apr 23, 2012 | 05:30 PM
Remove a spark plug wire, and a plug unless you have an extra one. Connect plug to wire, hold threaded end of plug against a good engine ground, and have someone crank the engine over. You might want to grab the plug gently with a pliers on the porcelain, to prevent your hair from curling!
Old Apr 23, 2012 | 08:53 PM
Jon ousley's Avatar
Alright I'll check for spark tomorrow after work. Thanks for the tip.
Old Apr 27, 2012 | 07:03 AM
Jon ousley's Avatar
Got the car running last night. It was a lose wire connection. Thanks for all the advice
BillsFan727
Jun 26, 2012 12:48 AM
BigD1988
82-92 V6 Tech
Oct 18, 2010 05:36 AM
BigD1988
82-92 V6 Tech
Jun 9, 2010 07:18 PM
chris n
67-69 V8 Tech
Nov 30, 2008 09:47 PM
inky21
Oct 20, 2007 02:50 AM
