1988 camaro wiring problem
Old Apr 16, 2012 | 09:36 PM
Jon ousley's Avatar
Default 1988 camaro wiring problem
Hi, I got a 1988 camaro and recently the car died on me and every time I try to start I get nothing I don't hear a click or anything. Could that be a bad starter. Please help
Old Apr 16, 2012 | 11:08 PM
Could be that the alternator died and the battery went flat. Have you tried a new battery or a jump start?
Old Apr 17, 2012 | 06:15 AM
Jon ousley's Avatar
No I haven't. I'll try that as soon as I get home from work. Thanks for the advice
Old Apr 18, 2012 | 08:57 PM
Jon ousley's Avatar
Well I tried jump starting it and another battery but still nothing. I noticed one of the wires running down to the starter was melted so I fixed it and I'm still getting nothing when I turn the key I don't even hear the fuel pump or anything. Where might the next place I should check. Thanks for your help again
Old Apr 23, 2012 | 06:48 AM
Jon ousley's Avatar
Well I replace the starter and I finally got the car running again but not for long. I went out yesterday to start up and nothing. The car would crank but wouldnt start. I can see the injectors spraying gas into the tbi. What should I do now. Oh the car has new plugs, wires, cap & rotor, and ignition control module. Any advice.
Old Apr 23, 2012 | 07:31 AM
torque_is_good's Avatar
does it fire up at all? If yes, does it ilde very slowly and chugs or does it run a few seconds and then dies? More details
Old Apr 23, 2012 | 08:45 AM
Melted against the exhaust, or did it melt on it's own out of the clear blue? Was that a fusible link (lump in the wire)? You would have a major short in your electrical system if it's the main supply wire that's melting on it's own (if that's the wire and that's what it did).
Old Apr 23, 2012 | 09:02 AM
Jon ousley's Avatar
It doesn't fire up at all. It just cranks. The wire melted on its on and I belive it was a fusible link. I cut the bad wire and replaced it and it doesn't melt anymore. My guess is it's not getting spark but I don't know where I should start looking.
Old Apr 23, 2012 | 10:27 AM
The fusible link is the "sacrificial lamb" of the electrical system. It's designed to melt/blow before something important burns, which prevents an electrical fire due to a short. If you replaced the link with a regular wire, watch out for smoke. But, the smoke signals will make it easier to find your short!
Old Apr 23, 2012 | 10:34 AM
Jon ousley's Avatar
I haven't seen any smoke or smelt burning wire since I replace it with regular wire. Thanks for the tip. Still need need to know where to start with the no spark issue thought. Any ideas?
