1987 350 TBI swap Wiring Help!!
Old Apr 10, 2013 | 02:23 AM
  #21
bobo87z's Avatar
Its a Carbuereted throttle body rochester quadrajet not newer style tbi.
i took the whole intake off the original camaro engine carb and all and installed it on the 350 out of the 1993 chevrolet 1500 pickup and also my camaro is 5 speed so what chip do i need for this setup?
Old Apr 10, 2013 | 09:12 AM
  #22
birdman11's Avatar
TBI Computer Chip for 350 F Body | eBay
That will work, send that guy a message if you want a 5 speed version of it.
Old Apr 10, 2013 | 09:53 AM
  #23
birdman11's Avatar
so for the 350 to be running at 100% i need new injectors and a new ECM ??
where can i find these items? do i need a new TBI? ^
birdman 11 says he can burn chips, what exactly does that mean and what will it cost me? how can i reach you?
Email me all the details @ bo_sandoval@yahoo.com
What ECM are you running now? Let me get this straight. This car was originally an 87 TPI car? Now you put in a 350 block and put TBI intake on it? Let me know
Old Apr 17, 2013 | 10:41 PM
  #24
bobo87z's Avatar
Default Wiring
The car is a 1987 camaro z28 which originally came with a 305 carbureted and T5 trans and i swapped the engine for a 350 but took the original intake/ carb off the 305 and placed it on the 350. now i have the 350 in place and have no clue to where all my connectors and wire plugs fit or where half of them go, does anyone know where i can see a diagram???
Old Apr 18, 2013 | 07:49 AM
  #25
birdman11's Avatar
Your confusing us here. Is it carb or throttle body? Throttle body injection is not carb. If it's throttle body injection. You need a TBI harness for an 89-92. Possibly a fuel pump for a TBI.
Old Apr 20, 2013 | 12:21 AM
  #26
bobo87z's Avatar
it has a Quadrajet on it...
Old Apr 20, 2013 | 12:51 AM
  #27
For the record, your year Z28 came both carbureted and TPI (fuel injected). You have a carburetor, it doesn't have injectors, and it's not a TBI.
I have a 3rd gen Haynes repair manual that has decent wiring diagrams. However, they aren't illustrated with pictures, you follow the wire's color coding schematic.
If you had a picture or two showing the wires and unused connections, that may help some.
Old Apr 24, 2013 | 09:37 PM
  #28
bobo87z's Avatar
I just went out and bought a HAYNES Repair manual so i should get it . . .
so with this setup all i need is to get a new PROM chip, i have the original Knock sensor that came on the 350, also will the T5 manual Trans hold up to the 350?
just wondering though, Does anyone think that just putting a Carb, tubular non EGR headers and going without any of the Emissions Control System on it would be best? but the Check Engine light probably would never shut off would it....
Old Apr 26, 2013 | 01:18 PM
  #29
bobo87z's Avatar
so all i really need is the new PROM chip for my computer and the TBI off the 305 will work for the 350?
what about all the SMog crap can i do without it i.e.: hoses/wiring.
Old Apr 26, 2013 | 01:30 PM
  #30
bobo87z's Avatar
Originally Posted by birdman11
No, it will only get it to run , not run properly. It won't run very well.The ecm will still think there are 305 injectors in there. That is one problem. It will only give you enough fuel to cover the small 19 lb 305 injectors! Not enough fuel. Also, he will need the 350 knock sensor, which is different also, and the 350 ESC module. The most important part of the swap is the prom chip though. THere are too many differences inside the chips between a 305 and 350. Trust me , I have been burning chips for years.
so i just need the PROM chip, i already have the knock sensor on the 350 it came with.
