1987 350 TBI swap Wiring Help!!
Old Mar 13, 2013 | 11:17 PM
bobo87z's Avatar
Default 1987 350 TBI swap Wiring Help!!
hello, i recently purchased a 87 z28 from a friend and it came with the stock 305 engine but it was no good so i have pulled it out and i recenlty acquired a 350 from a 1993 chevrolet 1500 truck, now im attempting to put into my camaro, i have put the original intake from the 305 and put it on the 350 , now im in trouble cause i forgot where every single wire plug and harness in the engine bay goes and i really need help if anyone can show me a diagram or some setup showing me where each connector plugs into the TBI and everything else i would greatly appreciate it..
Old Mar 16, 2013 | 11:27 AM
microkid's Avatar
March 2011 ROTM
Technical User
the plugs will only fit one sensor. lay it out, with the age, the wiring will be bent towards where it belongs. if you put the original 305 tbi on that engine as well, you will need to change the injectors and prom chip in the ecm for it to be running at 100%
Old Mar 17, 2013 | 11:26 PM
bobo87z's Avatar
well i do not have the ecm from the gmc 1500, and aslo i was wondering about the Flexplate it is the original one from the 305 will it still work with the 350? what do you mean by change the injectors? it has the orginal Throttle body and Intake and ECM from the 305, wont it work the same ??
Old Mar 18, 2013 | 05:51 AM
Everett#2390's Avatar
The flex plates should match up between the two years, however, check to make sure.
Use as much of the Camaro's parts as you can, you're just swapping out the long block.
If you used everything from the 305 intake manifold up and distributor, and bolted it onto the the 350, use as is for right now to get it running, including the 305 ECM. The ECM will learn to run the 350.
Old Mar 18, 2013 | 10:17 AM
birdman11's Avatar
Default custom chip
I burn chips and can make a really nice one for this swap. Your gonna need one anyway. Let me know
Old Mar 18, 2013 | 11:24 AM
bobo87z's Avatar
burn chips? whats that... and how much is it sgonna run me????,
im a little short on cash right now, i spent the rest of my cash on gaskets, wires/plugs, tubular shorty headers.
Old Mar 18, 2013 | 07:32 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
A good tune- necessary any time you go with fuel injection, should run you between $200 and $450, depending where you're located, where you take it, and if, like me, you made the mistake of using a mail-order chip. Do your research, find a shop that knows what they're doing, and bring the car to them. Make sure they know exactly what parts are in your engine (part numbers are good) and let them do their thing.
I tried a mail order chip from pcmforless- gave them the details of my engine down to every last bolt, and wound up running very rich and making less power than I did with my stock 305.
Old Mar 19, 2013 | 10:34 AM
birdman11's Avatar
I can burn a chip for $50. It will really "wake" that thing up!
Old Mar 19, 2013 | 10:38 AM
birdman11's Avatar
No, it will only get it to run , not run properly. It won't run very well.The ecm will still think there are 305 injectors in there. That is one problem. It will only give you enough fuel to cover the small 19 lb 305 injectors! Not enough fuel. Also, he will need the 350 knock sensor, which is different also, and the 350 ESC module. The most important part of the swap is the prom chip though. THere are too many differences inside the chips between a 305 and 350. Trust me , I have been burning chips for years.
Old Apr 3, 2013 | 08:10 PM
bobo87z's Avatar
injectors? no fuel injectors. its Throttle Body Injection
Rochester Quadrajet. i dont have the ECM from the truck the 350 came out of so what do i need to do?
