1987 350 TBI swap Wiring Help!!
Old Apr 4, 2013 | 01:58 PM
birdman11's Avatar
Originally Posted by bobo87z
injectors? no fuel injectors. its Throttle Body Injection
Rochester Quadrajet. i dont have the ECM from the truck the 350 came out of so what do i need to do?
What intake did you put back on the car? The 87 z28 305 intake? If so, it should be a TPI intake. If you put a Thirdgen TBI intake on the car then you need to use a TBI harness and ECM w/correct prom chip.
Old Apr 4, 2013 | 02:01 PM
birdman11's Avatar
If you put a TBI intake on the car. Yes, you need to be using a TBI harness, the 8746 ECM and this chip:
TBI Computer Chip for 350 F Body | eBay
Old Apr 4, 2013 | 08:08 PM
bobo87z's Avatar
Default ECM Chip
so for the 350 to be running at 100% i need new injectors and a new ECM ??
where can i find these items? do i need a new TBI? ^
birdman 11 says he can burn chips, what exactly does that mean and what will it cost me? how can i reach you?
Email me all the details @ bo_sandoval@yahoo.com
Old Apr 5, 2013 | 09:20 AM
birdman11's Avatar
You will need the following: TBI intake manifold, TBI throttle body ( You can use the 305), 65lb injectors, ECM # 12278046 (you can use one from a 305) , 350 TBI ANLU Prom chip,350 knock sensor, ESC module.
Old Apr 5, 2013 | 09:49 PM
juice+'s Avatar
sorry to but in here but i was reading this and had my own question about chips. I took an 87 iroc 5speed manual, and swaped the 305 tpi, for a 350tpi out of an 88 z28. From reading this i think i need to change my chip in my ecm from a 305 chip to a 350 chip? and i saw some on ebay, but my question is does it matter if the the car is an automatic or standard when buying a chip?
Old Apr 6, 2013 | 09:59 AM
birdman11's Avatar
Yes it does matter, there are a ton of differences between an auto and manual chip. For a 350 manual trans car, you would need a custom chip because they never made a 350 with a manual trans
Old Apr 7, 2013 | 03:50 PM
juice+'s Avatar
what if i just left in the stock chip and got a adjustable fuel regulator, and adjust my timing? or do i deffinatley need to change the chip?
Old Apr 8, 2013 | 10:12 AM
birdman11's Avatar
No , you will need another chip.
Old Apr 8, 2013 | 05:11 PM
microkid's Avatar
March 2011 ROTM
Technical User
well, which is it? tbi or q-jet?
Old Apr 8, 2013 | 07:25 PM
  #20
Rochester makes the TBI, he may have made a slip.
