Are 15" & 16" interchangable
Old Nov 15, 2005 | 12:08 AM
The_Shadow's Avatar
Default Are 15" & 16" interchangable
I have an 89 RS with 15" rims and an 89 IROC with 16" rims.
Is the bolt patterns the same on both?
I'm curious, if I needed a temp spare if I could put a 15" rim & tire on my IROC?
Thanks
Old Nov 15, 2005 | 12:40 AM
Default RE: Are 15" & 16" interchangable
The bolt pattern should be the same. If u have limited slip diff, it is not a good idea to have different size wheels on the rear axle. Tends to eat up the posi clutches.
Old Nov 15, 2005 | 05:50 AM
The_Shadow's Avatar
Thanks
I’ll make sure to keep it on the front if I have use it temporarily.
Old Dec 24, 2005 | 08:25 PM
beast85's Avatar
if you do have to temporarily change the rear wheels just take both sides off the other as well. they are exactly interchangable throughout all gen 3 years. whether its rs, z28, or iroc lugs are the same.
lsat
Jun 13, 2011 10:03 AM
carguy04
May 8, 2008 07:32 PM
jagman454
Dec 14, 2007 08:37 AM
