**Battery Problems**
Old Sep 21, 2006 | 05:49 PM
trailerparktrash2009's Avatar
Default **Battery Problems**
Hello,
ok so i just put in a new battery not but about a week ago..and i havent cranked it or anything except once..at first we thought the stereo was draining the battery so i didnt hook it back up..i swithced the battery terminal things..first i turned on the fan..when i went to crank it..the battery all of a sudden died..what is the problem?? can it be fixed and how much would it cost??
Old Sep 21, 2006 | 06:13 PM
Blade's Avatar
June 2007 ROTM
Default RE: **Battery Problems**
can u give more info? are u possibly leaving the dome light on? did u change out the alternator? if not sounds like a short and they are extrememly hard to locate.
Old Sep 21, 2006 | 06:20 PM
the dome light stays off when i close the door..i havent changed the altanator..but since im never driving the car it shouldnt drain the battery should it??
Old Sep 21, 2006 | 06:29 PM
350rs's Avatar
March 2008 ROTM
what do your volts read before you try and start it? should be right around 12... if not, just a do a quick check on your connections and terminals, make sure everything is tight, could just be a poor connection.
Old Sep 21, 2006 | 06:37 PM
thanx..ill go check the connection right now..i cant tell how many volts show right now..cuz the battery acts like its dead..
Old Sep 21, 2006 | 07:16 PM
Goodfella's Avatar
A bad alternator is sometimes notorious for draining batteries. something you might want to check
Old Sep 21, 2006 | 07:20 PM
MadMikeZ28's Avatar
Is the battery dead or maybe your starter. If you had a weak battery before it is possible it killed the starter. When you hook up the battery (while it has a good charge) and you see a big spark as you touch the last terminal to the battery you have a drain going on somewhere.
Old Sep 22, 2006 | 07:53 AM
Found out it was just a bad connection..everythings goin good now..thanxx everyone for your help
libertyforall1776
Feb 24, 2014 02:11 PM
BillsFan727
Feb 6, 2012 11:24 AM
DOC'S Z28
Apr 17, 2010 08:52 AM
typeomang
Feb 9, 2009 10:30 AM
bowtieguy
Jan 5, 2009 10:44 PM
