Which V8 is it?
Old Nov 27, 2010 | 05:00 PM
swiftb's Avatar
Default Which V8 is it?
Recently bought a 79 T-top project and while doing my reseach found out that the VIN info for the engine doesn't match what I was told it was. The VIN code is G which I understand to be the 305 but the guy i bought it from said it was a transplanted 350. I am not good at visually IDing the difference, any suggestions on how to tell?
Old Nov 27, 2010 | 05:20 PM
Old Nov 27, 2010 | 05:31 PM
swiftb's Avatar
Exactly what I was looking for. Thanks a ton. While I am at it any suggestions for IDing the tranny?
Old Nov 27, 2010 | 07:10 PM
If you're talking about an automatic, the shape of the pan tells what type it is: http://www.nastyz28.com/chevy-transm...tification.php
Old Nov 27, 2010 | 07:41 PM
swiftb's Avatar
Fantastic. Again exactly what I was looking for. Turns out the car has a '75 350 with a TH350 attached. Tranny has a B&M shifter so it makes me wonder if it has a kit in it. Pan has a leak on it so it has to come down anyway, geuss there is one way to find out about the kit.....
Old Nov 27, 2010 | 08:27 PM
You wont be able to see anything that will indicate a shift kit when you pull the pan. Only way to tell would be to pull the valve body and compare the gasket to a B&M gasket.
