TPI question
Old Nov 7, 2011 | 02:30 PM
Dreamcatcher's Avatar
Default TPI question
I am about to install an 89 TPI IROC 350 in our 74 camaro.I need to know if anyone knows of a fuel pump that might fit my stock tank to run the fuel injection or of a tank that will fit the 74 camaro.Also can I use my older turbo 400 transmission with this even though there is no hook up for the computer.
Thanks
Old Nov 8, 2011 | 02:10 PM
bad436z28's Avatar
Default efi
its pretty easy fix,go get an external inline pump from summit part #sum-g3138,then just rig up a return line to the tank should already be one.thats the way i done mine.good luck ur gonna love ur efi.but make sure u get fuel line rated at the pressure u intend to run,should be 43-45 psi that usually is the way to go.
Old Nov 8, 2011 | 04:08 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
heres one a guy did on a 74 nova..might help you out
http://www.stevesnovasite.com/forums...&highlight=TPI
Old Nov 8, 2011 | 05:59 PM
To answer your T-400 trans question, yes you can use it no problem. The 400 downshifts electrically, and you can hook up the momentary switch either at the throttle linkage or at the gas pedal.
Old Nov 8, 2011 | 07:52 PM
The 400 transmission I want to use is an older one that was in the camaro.It dosent have any electronics on it.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
