TPI question
I am about to install an 89 TPI IROC 350 in our 74 camaro.I need to know if anyone knows of a fuel pump that might fit my stock tank to run the fuel injection or of a tank that will fit the 74 camaro.Also can I use my older turbo 400 transmission with this even though there is no hook up for the computer.
Thanks |
efi
its pretty easy fix,go get an external inline pump from summit part #sum-g3138,then just rig up a return line to the tank should already be one.thats the way i done mine.good luck ur gonna love ur efi.but make sure u get fuel line rated at the pressure u intend to run,should be 43-45 psi that usually is the way to go.
heres one a guy did on a 74 nova..might help you out
http://www.stevesnovasite.com/forums...&highlight=TPI |
To answer your T-400 trans question, yes you can use it no problem. The 400 downshifts electrically, and you can hook up the momentary switch either at the throttle linkage or at the gas pedal.
(Post 583086)
